Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
davidr1
Jul 11, 2012Luminary
Thanks for your reply, StephenB
My apologies - different forums different procedures. Noted for the future. I notice other threads are guilty too, then.
So I would end up with:
Left port: usb drive
Right Port: usb hub:
USB drive
UPS
And so that should be OK to monitor the UPS and use the USB drive at the same time? Just want to be clear ...
David
You should have started your own thread (generally we don't resurrect ancient history).
USB drive
UPS
David
