Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
Jul 11, 2012Guru - Experienced User
I think that should work, though the USB hub will need to be connected to the UPS, otherwise monitoring would be lost when power fails. I think I would try putting both drives on the USB hub, and keeping the UPS on its own port.
