kiokoman
May 23, 2012Aspirant
How to Install PHP5 and phpmyadmin joomla(arm) duo v2
work on T33 and T41 you need to Enable Root SSH on the ReadyNAS. my english is not very good so i will make it short: apt-get install nano libapache2-mod-php5 php5 php5-mysql php5-gd phpmyad...
kullyrai
Dec 17, 2012Tutor
Hi,
I recently bought a ReadyNAS Duo v2 (arm) and wanted to set-up my own php webserver on it.
The ReadyNAS has the official firmware RAIDiator v5.3.7
I tried to install PHP5 and phpmyadmin as per the instructions above, but I received the following error message:
Should I proceed with the 'apt-get -f', or could this cause issues?
thanks
kullyrai
root@ReadyNAS:/# apt-get install nano libapache2-mod-php5 php5 php5-mysql php5-gd phpmyadmin
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
libapache2-mod-php5 : Depends: libonig2 (>= 5.2.0) but it is not going to be installed
Depends: libqdbm14 (>= 1.8.74) but it is not going to be installed
Depends: php5-common (= 5.3.3-7+squeeze14) but it is not going to be installed
Recommends: php5-cli but it is not going to be installed
libncurses5-dev : Depends: libc-dev
libncursesw5-dev : Depends: libc-dev
php5 : Depends: php5-common (>= 5.3.3-7+squeeze14) but it is not going to be installed
php5-gd : Depends: libgd2-xpm (>= 2.0.36~rc1~dfsg) but it is not going to be installed
Depends: libt1-5 (>= 5.1.0) but it is not going to be installed
Depends: libx11-6 but it is not going to be installed
Depends: libxpm4 but it is not going to be installed
php5-mysql : Depends: php5-common (= 5.3.3-7+squeeze14) but it is not going to be installed
phpmyadmin : Depends: php5-mcrypt but it is not going to be installed
Depends: dbconfig-common but it is not going to be installed
Depends: libjs-mootools (>= 1.2.4.0~debian1-1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
thanks
kullyrai
