kiokoman
May 23, 2012Aspirant
How to Install PHP5 and phpmyadmin joomla(arm) duo v2
work on T33 and T41 you need to Enable Root SSH on the ReadyNAS. my english is not very good so i will make it short: apt-get install nano libapache2-mod-php5 php5 php5-mysql php5-gd phpmyad...
mcmonkeys1
May 23, 2014Aspirant
rampa99 wrote: you should just add the apt-get update
apt-get install -f
at the start of the tutorial cause it was what was missing to make it work for me.
I can tell you from bitter experience that it's not a good idea to go forcing (-f) apt to ignore errors willy nilly. Imagine an unbootable system and TBs of data lost.
