apeofjungle
Jan 09, 2012Aspirant
How to keep DLNA / UPNP in the correct folders
If your connect to your NAS via DLNA and the files aren't all in the correct folders, you can fix this by adding another directory to the share. So if you have \video\movies\ \video\tv\ \video\h...
kllngtme
Jan 10, 2012Aspirant
This happens to me as well no matter what media player I use. I figured it was a bug with the Readynas... That seems to be a little rediculous of a fix, I want to have less folders, not more. Especially if it's just so the files will show in the correct folder..
Any devs out there aware of this bug? I really thought I was the only one. Thanks for bringing this up apeofjungle.
I'm hoping this can be resolved with a FW update instead of having a video folder within a video folder...
