apeofjungle
Jan 09, 2012Aspirant
How to keep DLNA / UPNP in the correct folders
If your connect to your NAS via DLNA and the files aren't all in the correct folders, you can fix this by adding another directory to the share. So if you have \video\movies\ \video\tv\ \video\h...
apeofjungle
Jan 16, 2012Aspirant
Someone once told me it's the way the standard works, not the way that ReadyNAS implements it. Either way, it's annoying, and this is a fix for it. Slightly annoying when looking at the folders via a computer, but much nicer on a media player.
