randomnut1
Jul 01, 2012Apprentice
How to log an RMA?
Hi, I am a bit confused about how Netgear offer support for the readynas. My original Duo died. Some kind of PSU failure. Just wouldn't turn on, therefore I was certain it had to go back for RMA r...
PapaBear1
If it is simply the PSU for the Duo, they should be able to ship you another since it is separate from the device itself. I do not know if they want you to send the failed PSU back.
Since you have an RMA number, you may want to edit your first post and append it to the end of the subject line.
Have you had any contact or instructions from them since you got the RMA number?
