randomnut1
Jul 01, 2012Apprentice
How to log an RMA?
Hi, I am a bit confused about how Netgear offer support for the readynas. My original Duo died. Some kind of PSU failure. Just wouldn't turn on, therefore I was certain it had to go back for RMA r...
mdgm-ntgr
Jul 01, 2012NETGEAR Employee Retired
Depending on the issue they may wish to do troubleshooting before approving an RMA. It's nice to know that you can fall back to using online support if you need to.
