ilansch's avatar
ilansch
How to manage ReadyNAS 6.5.1 OS not via WEB Admin?
Hi, How end-user usually control/manage the ReadyNAS appliance ? I can control/manage via Web browser. Does it provide another way - not via web ?  I can do it via SSH - but it is disabled and not...
  • StephenB's avatar
    Nov 30, 2016
    ilansch wrote:
    Yes, I know i can open wireshark/fiddler, figure out the http post/put and run them from my shell instead of a browser. Does customer do it ??
    I am not trying to bypass the web admin - I just want to know if there are alternatives.
    I'm not sure why you need alternatives - sometimes I do need ssh for things the web ui doesn't do, but it's risky to try and manually create shares, etc.
    Personally I use the web ui to configure my various ReadyNAS.  I do have ssh enabled on all of them, and used that to install/maintain crashplan (which is on an OS-4 system).  But generally I only use ssh for monitoring and occasional troubleshooting.
    RAIDar 6.x has some new features related to management - the ability to download logs, and a diagnostic mode.
    ilansch wrote:
    Enabling SSH on the server may cause deny from support - this is a fact.
    "May" is the key word.  Simply enabling ssh shouldn't result in a denial of support (despite the warning).  There is more information on that here: http://kb.netgear.com/app/answers/detail/a_id/30068
ProSupport for Business
