NASNoob11's avatar
NASNoob11
How to 'print' the HCL?
I will suppose I have a glitch with FF 13.0.1, but, each time I try to print a selected HCL list, all I seem to print (3 pages) is the opening text, my choice, the top several entries (big drives!), and, the bottom text of the 'list' (?frame?). :?
Is it me or the HCL list logic?
Long ago (2008) the entire HCL would print out.
Would like to do some HCL choice research prior to a buy of 4 hard drives.
  • StephenB's avatar
    try right-clicking in the middle of the list and selecting "print frame"
  • StephenB's avatar
    I tried printing to PDF with FF 13.0.1 and got the same thing NASNoob did. Right-clicking on the list and selecting "print frame" solved it.
    StephenB,
    Thank you. Yes, this trick worked perfectly. And, I learned a new XP sub-menu also! :)
    Have the full list and can continue research/choice for drives.
  • I am glad you were able to get that printed out, just make sure to check back for changes as this is a live list that could be updated at any time.
  • There is no option to print frame in chrome or IE8 in the context menu.
ProSupport for Business
