louprestia
Sep 09, 2020Aspirant
How to restore music to a reformatted NAS
I have a ReadyNAS Pro 6 RNDU6000. I just backed up all the data from it and did a factory reset. Then I upgraded it to OS 10 and put a pair of new larger drives in it to expand storage. I have fo...
- Sep 09, 2020
I'd reload the files over the network. There are some tools that can check file integrity. I believe FreeFileSync has an advanced option that can verify (likely there are other programs that can do this also).
Sep 09, 2020Guru - Experienced User
