louprestia
Sep 09, 2020Aspirant
How to restore music to a reformatted NAS
I have a ReadyNAS Pro 6 RNDU6000. I just backed up all the data from it and did a factory reset. Then I upgraded it to OS 10 and put a pair of new larger drives in it to expand storage. I have fo...
- Sep 09, 2020
I'd reload the files over the network. There are some tools that can check file integrity. I believe FreeFileSync has an advanced option that can verify (likely there are other programs that can do this also).
Sep 09, 2020Guru - Experienced User
louprestia wrote:
4. It apears all the factry defualt shares show the same size, Should I try toi re-size these so that the music volume its larger than the otherws? Or will all the volumes "share" the total space on rhe NAS so that this is not required?
If you have one volume, then all the space is shared. I think you are confusing the meaning of the "available space". That is the full free space left on the volume, and it will be the same value for every share in the volume.
