bigpallooka
Jul 22, 2012Aspirant
How to test Seagate 2TB HDD's in my RND4000?
SeaTools won't scan my drives in the RND4000 which is connected to my router. Is their a tool that will or a way to make it work with SeaTools? I am hearing a random squeaking noise and want to find o...
maxblack
Jul 23, 2012Aspirant
bigpallooka wrote: I am hearing a random squeaking noise
It does occur to me that I recently tripped across a Seagate firmware update that suggested it might fix drives that "chirped". So depending on what drives you have you should look for a new FW update possibility, and do that when you pull the drives.
I do NOT know, however, that the FW update is possible via a USB adapter...
