psteel's avatar
psteel
Tutor
Dec 20, 2017
How to use files search
Hi
Been using readynas for several years but only just turned on the file search function. Dumb question but how do I use it. Looked through the various user interfaces but cant find any which shows a file search function. System - settings - services file search is turned on (ie green), but cant seem to find a file search function anywhere else so still using file search in windows.
Never had to use this function so just playing really but interested to know.
Can anyone advise.
  • Hi psteel,
    On the ReadyNAS admin page, you can go to Shares then Browse. You should be able to see there a Magnifying Glass to open the search box. You can visit this link as well for reference.
    JohnCM_S
    NETGEAR Community Team
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi psteel,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    JohnCM_S
  • JohnCM_S's avatar
    JohnCM_S
    Hi psteel,
    JohnCM_S
ProSupport for Business
