theacoustician
Jul 24, 2010Aspirant
[How-to]Install Tonido on a x86 ReadyNAS device
I posted this over at the Tonido forums and I thought I'd post it here in case anyone was curious on how to do this. It seemed more appropriate to post here as opposed to th add-on section since it's not a packaged .bin
If you don't know what Tonido is, check http://www.tonido.com first
Disclaimer
This is a quick guide to installing Tonido on your x86 series ReadyNAS (NXV, Pro, or Ultra) and has only been tested on RAIDiator 4.2.12. While this is fairly simple because the ReadyNAS runs Debian Etch, keep in mind this may void your warranty or cause your device to behave in unpredictable ways. I've tested it out fairly thoroughly and had zero problems, but your mileage may vary. Now that the warning is out of the way, here we go.
Installing Tonido on a ReadNAS
Optional to get Tonido to run at every bootup
Note that this doesn't seem to be the direction the ReadyNAS SDK was pointing me in, but it seemed to be the only reliable way for it to start every boot up.
Stopping Tonido from running at bootup
Uninstalling Tonido
And there is no more Tonido.
Additional Information
Tondio does seem to make the ReadyNAS slightly less snappy than a default configuration on a ReadyNAS NVX. I'm thinking that upgrading the RAM on the device will help solve this. Because of the increased specs on the Pro and Ultra, the hit shouldn't be as noticeable.
Disabling the torrent client in Tonido seems to have the biggest boost on performance without a hardware upgrade. I think this is because of the mass of tracker requests you get from running it. I had a ton of traffic on port 6881 even though I never did anything with the torrent app, but disabling it made that go away as well as making everything (the NAS console and Tonido) seem snappier.
Performance overall is still quite acceptable for a home user and I can still stream 1080p video off the NAS to playback anywhere on the local network.
Remember to enable port forwarding on 10001 if you want to reach your NAS outside your home network and allow for UPnP if you want to use all Tondio plug-ins (Torrent, etc.).
If you have any issues, please let me know.
Disclaimer
- Download and install the RootSSH add-on from Netgear.
- SSH into your ReadNAS and type the following at command prompt
wget http://www.tonido.com/download.php?TonidoSetup_i686.deb
- Then
dpkg --force-all -i TonidoSetup_i686.deb
It will complain about a libfreetype6 being too old and possibly a few other things, but they are all apparently all related to running Tonido on a local GTK session. Since there's no monitor output for the ReadyNAS, this doesn't matter. - You need to run Tonido once to get it to generate a config file.
/usr/local/tonido/tonido.sh start
- Now type
vi ~/tonido/data/configex.xml
and scroll down to the section that says<rowentry>
<name>WebAccess</name>
<type>string</type>
<value>local</value>
</rowentry>
<rowentry>
<name>RemoteAdmin</name>
<type>bool</type>
<value>0</value>
</rowentry>
Change the 0 between the value tags to a 1. If you aren't Linux savvy, type a to start editing, then hit Esc to stop in vi. To exit the file, hit Esc and then type :wq and hit Enter. All done. - Type
/usr/local/tonido/tonido.sh restart
to restart Tonido with your config file changes. - Log into Tonido for the first time by opening a web browser and going to
http://*IP address of your device*:10001
You'll be prompted to create an account. Once done, you should see your Tonido screen. You can follow the wiki from here on out.
- SSH into the ReadyNAS if you aren't already and type
cp /usr/local/tonido/tonido.sh /etc/init.d/tonido.sh
- Type
update-rc.d tonido.sh defaults
- From SSH, first
update-rc.d tonido.sh remove
rm /etc/init.d/tonido.sh
Uninstalling Tonido
- If you had Tonido running at boot, do the above steps under Stopping Tonido from running at bootup first
- Then
dpkg --purge tonido
- Finally
rm ~/TonidoSetup_i686.deb
- super_poussinVirtuosowill do the test :)
- super_poussinVirtuosoyou can update directly from Tonido , it works fine :)
- caribouAspirantTonido gets interesting for ReadyNas device users. Tonido iPhone app is available in the app store now.
Using the app you can browse the files in your ReadyNAS & stream music.
Some screenshots of Tonido iPhone app if you are interested
- theacousticianAspirantMore interesting ... they have Blackberry and Android apps available as well. I'm demoing the Android app right now.
- theacousticianAspirantOk, I've found a bug in the Tonido plugin and I think it might exist in this method too.
The Jukebox is broken. You cannot stream music. FFMPEG is used by Tonido to transcode and stream on the fly. However, if you check FFMPEG on your box...
mediavault:/usr/local/tonido/plugins/jukebox# ldd ./ffmpeg.exe
linux-gate.so.1 => (0xb7785000)
libz.so.1 => /usr/lib/libz.so.1 (0xb776a000)
libm.so.6 => /lib/libm.so.6 (0xb7744000)
libvorbisenc.so.2 => not found
libvorbis.so.0 => /usr/lib/libvorbis.so.0 (0xb771b000)
libpthread.so.0 => /lib/libpthread.so.0 (0xb7703000)
libc.so.6 => /lib/libc.so.6 (0xb75c5000)
/lib/ld-linux.so.2 (0xb7786000)
libogg.so.0 => /usr/lib/libogg.so.0 (0xb75c0000)
The reason seems to be because libvorbisenc.so.2 missing. There may be other reasons, but this seems like the big one. The problem is that I can't seem to find a .deb for it. I've tried apt-get, but...mediavault:/usr/local/tonido/plugins/jukebox# apt-get install libvorbisenc2
Reading package lists... Done
Building dependency tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
libfontconfig1: Depends: libfreetype6 (>= 2.3.5) but 2.2.1-5+etch3 is to be installed
Depends: fontconfig-config (= 2.6.0-3) but it is not going to be installed
tonido: Depends: libfreetype6 (>= 2.3.5) but 2.2.1-5+etch3 is to be installed
Depends: fontconfig (>= 2.4.2-1.2) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Using the -f swtich will force Tonido to uninstall and a few other things it would seem. I'm working on a solution, but if someone else can figure it out in the mean time, that would be swell. - theacousticianAspirantOk, it's a lot easier to fix this once you actually find a deb for it :D
Log in via SSH
wget http://security.debian.org/pool/updates/main/libv/libvorbis/libvorbisenc2_1.1.2.dfsg-1.4+etch1_i386.deb
Then install via dpkg
dpkg -i libvorbisenc2_1.1.2.dfsg-1.4+etch1_i386.deb
Streaming should work now. - ScottChapmanApprenticeSo...
Anyone know how to re-use a tonido account?? - TarvAspirant
ScottChapman wrote: So...
A newer version of Tonido is required before you can recover an account. The version installed with PRO-Tonido_1.2.bin does not have the recovery option.
Those without Root access will have to wait until a new install BIN is released. 8)
If you have root access, you can update manually. Disable the add-on from FrontView before you update.wget http://www.tonido.com/download.php?TonidoSetup_i686.deb
Re-enable add-on after you update.
Recovery instructions: http://www.tonido.com/support/display/d ... count+name - SergeB1AspirantThanks for your instructions. I used them to install Tonido on ReadyNAs Pro2. I'm new to Tonido, but not new to UNIX.
I tryed to install Tonido before using adds-on, did not work for me. I removed everything and started from scratch.
Hoped, your instruction will do the trick. Nope.
Installation was smooth. No issues or errors. Tonid process "tonidoconsole" is running. Created new account. No issues. Have a login screen, but cannot login. Windows IE just hangs after password entered. iPhone displayed the meesage: "Failed to connect to server". Am I missing something ?
Your advice will be greatly appriciated.
SergeB :?
