Bran_Scone's avatar
Bran_Scone
I can update Firmware from 6.7.4 asf the AntiVirus is out of date and wont download.
My ReadyNAS is currently runnig on 6.7.4 and i cant seem to update. I also have an issue with the Antivirus as its out of date and wont update. I hagve an error on the log also ;
Volume: System volume root's usage is 100%. This condition should not occur in normal conditions. Contact technical support.
Need Help
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi Bran_Scone,
    Welcome to the Community!
    May I know the model number of your ReadyNAS device?
    The OS partition of your NAS is full based on the error that you got. One of the common causes is 3rd party apps that are installed on that said partition. Do you have any apps that you have installed using SSH?
    Also, if your NAS is an RN100 series, there was an issue before on those models wherein the anti-virus is causing an excessive usage of the root partition.
    It will be best if you contact NETGEAR support so they can check what caused the full OS partition and free it up for you as well. Please do note that you will need to pay for the support if the device is already out of support warranty.
    If you are also comfortable in accessing the NAS via SSH, you may also do that and check what is causing the full OS partition.
    • Bran_Scone's avatar
      Bran_Scone
      ReadyNAS OS 6 104
      I think as I cant get access today as its failing to start-up, stuck on the;
      Booting...
      from the LED display. Switch it off and on a couple of time no improvement.
ProSupport for Business
