JBDragon1
May 23, 2020Virtuoso
I can't Update software on my NAS. I even tried to delete and that failed.
I'm trying to Update PLEX and it's been failing. I just tried updating EMBY and that is doing the same. Both are failing to Update. I even tried to delete PLEX and that failed. What is going on? ...
May 23, 2020Guru - Experienced User
Have you checked for a full OS partition/
- JBDragon1May 23, 2020Virtuoso
It shows 6.10 TB free.
- StephenBMay 23, 2020Guru - Experienced User
No. You are confusing the data volume with the OS partition. Likely your OS partition (which is only 4 GB - not TB) is full.
Do you have ssh enabled?
You can use the procedure here to analyze and possibly fix it: https://community.netgear.com/t5/New-ReadyNAS-Users-General/ReadyNAS-214-System-Volume-root-useage-90/m-p/1738485#M36253
OK, so MNT is showing like 2.3G Total.
