JBDragon1
May 23, 2020Virtuoso
I can't Update software on my NAS. I even tried to delete and that failed.
I'm trying to Update PLEX and it's been failing. I just tried updating EMBY and that is doing the same. Both are failing to Update. I even tried to delete PLEX and that failed. What is going on? ...
JBDragon1
It shows 6.10 TB free.
May 23, 2020Guru - Experienced User
No. You are confusing the data volume with the OS partition. Likely your OS partition (which is only 4 GB - not TB) is full.
Do you have ssh enabled?
You can use the procedure here to analyze and possibly fix it: https://community.netgear.com/t5/New-ReadyNAS-Users-General/ReadyNAS-214-System-Volume-root-useage-90/m-p/1738485#M36253
- JBDragon1May 23, 2020Virtuoso
OK, so MNT is showing like 2.3G Total.
- StephenBMay 24, 2020Guru - Experienced User
That's not full, but has less free space than usual.
Can you post the output of btrfs fi df /mnt ?
Also, what other apps do you have installed?
- JBDragon1May 24, 2020Virtuoso
This is what I get.
Data, single: total=3.58GiB, used=2.32GiB
System, DUP: total=8.00MiB, used=16.00KiB
Metadata, DUP: total=204.56MiB, used=24.77MiB
GlobalReserve, single: total=16.00MiB, used=0.00BAs for other Apps. I have EMPY which is simular to PLEX. Tautulli which gives me al kind of usage Data for PLEX. netdata NT, stat, these 2 I've had off for a while. I haven't used them in a while. EMPY I normally have off. I have it to play around with. Then there's a few programs I've manually installed by SSH into the NAS like NZBGet, Sonarr and Radarr. These 3 programs of course don't show up in the installed apps page. I've been using this setup for a number of years now. I haven't touched anything, or change anything recently. I tried to installed a new PLEX update and it failed. So I assumed it was PLEX. But there's been like 6 updates since and they all fail. I've since tried to Delete PLEX and that fails. Delete EMBY, that fails. etc. Update fails. Many times when I try to update or Remove, the NAS I don't now, CRASHES? It goes to a new page saying Connecting to the ReadNAS Admin Page... Then I have to log back in again.
I do have the WinSCP program installed on my Windows computer to access my NAS that way. Makes it quicker, easy to delete stuff. My PLEX Media Server Backup directory I didn't change. So it was going into the Default. Is that the same limited Partition??? I moved the Plex Transcoding folder out to my Media Folder. Do I need to do that with the Backup? I assume that's a backup, but then I'm not sure where the normal PLEX files are at, and if there's 2 copy's in this limited space? The Main and the Backup?
