JBDragon1
May 23, 2020Virtuoso
I can't Update software on my NAS. I even tried to delete and that failed.
I'm trying to Update PLEX and it's been failing. I just tried updating EMBY and that is doing the same. Both are failing to Update. I even tried to delete PLEX and that failed. What is going on? ...
JBDragon1
May 28, 2020Virtuoso
Normal, as in Admin Web UI.
AS for Logs, I get this,
-- Logs begin at Mon 2020-05-25 15:03:48 PDT, end at Thu 2020-05-28 18:09:39 PDT. --
May 27 21:34:24 READYNAS fv-app-install[17747]: [/tmp/plexmediaserver_1.19.3.2852-219a9974e_amd64.deb](0%) prepare
May 27 18:10:26 READYNAS fv-app-install[1897]: [tvmosaic](0%) prepare
May 27 18:07:48 READYNAS fv-app-install[1026]: [/tmp/emby-server-netgear_4.5.0.11_amd64.deb](0%) prepare
-- Reboot --
May 26 21:11:13 READYNAS fv-app-install[16725]: [/tmp/emby-server-netgear_4.5.0.11_amd64.deb](0%) prepare
May 26 18:49:46 READYNAS fv-app-install[7325]: [couchpotato](0%) prepare
-- Reboot --
May 26 18:20:47 READYNAS fv-app-install[16739]: [/tmp/emby-server-netgear_4.5.0.11_amd64.deb](0%) prepare
Then it looks like I have a bunch of these. I'm showing the last 2.
Start-Date: 2020-05-27 21:34:26
Commandline: apt-get -qq install --fix-broken
Upgrade: vim-runtime:amd64 (2:7.4.488-7+deb8u3, 2:7.4.488-7+deb8u4)
Error: Sub-process /usr/bin/dpkg returned an error code (1)
End-Date: 2020-05-27 21:34:29
Start-Date: 2020-05-28 10:03:41
End-Date: 2020-05-28 10:03:48
JBDragon1
Ok, after looking closly at the errors, it was vim giving me issues. Some kind of error it had was now allowing anything else to be installed. So I uninstalled it. EMBY installed normally after than. PLEX, seem to be working, and then it rebooted. But looking at PLEX, it seems to have been updated. So that was strange. Will have to see if that happens again with the next PLEX update.
