kkoshy
Oct 10, 2023Follower
I have 20 computers across 2 office locations - how to backup in this scenario
Office location 1: 20 computers. Office location 2: 5 computers NAS drive is located in this office. Problem to be solved: I want to backup all my computers to this NAS Drive. C...
Oct 11, 2023Guru - Experienced User
kkoshy wrote:
any pointers - any pointers would be very much appreciated.
NiveditaP3 - I can't see most of the screen shots on the second KB article. The site they are stored on looks like it has been taken down. The second image in the article (the first I can't see) has a URL of
http://support1.gearguy.com/useruploads/images/0%286%29.png
kkoshy: Note both of articles that NiveditaP3 provided require set up on the PCs, which I think you want to avoid or minimize. They also don't discuss Win 11, you should be able to set this up on Win 11 also. The article doesn't say this, but you need to set up distinct destinations for each user.
Solving this problem at scale w/o depending on end-users usually involves having a way to remotely push and provision software to the user PCs. If you don't have that, then either you or the users will have to do some work on each PC. Note that while users might not all cooperate, you can look at the backup destinations on the NAS, and see which ones are not compliant.
Another class of solutions is to deploy cloud backup (not using the NAS). OneDrive is the natural place to look first if you are using Windows PCs.
- SandsharkOct 11, 2023Sensei
To do what I consider a "proper" backup of a Windows computer has to start with something installed on the machine itself, as no external process is going to be able to back up system files or any that are open. Step one has to be the creation of a shadow copy, then that is what is backed up.
If you are the boss and your employees are that open about ignoring what you tell them to do, then that's a problem we can't help you solve. But it's pretty easy with most backup software to go to the backup location and verify that backups are being created. You just have to decide what you are going to do if they aren't.
I even check that backups are being created for my own PC's, to verify nothing has gone wrong. I actually did find that to be the case once and fixed it.
