snorkleboy13
Jun 15, 2017Aspirant
I have a ReadyNAS NV+ running 4.1.14 and want to switch networks
For years I had my ReadyNAS NV+ running 4.1.14 on my home network using wrt54GS wireless routers with Tomato installed. They run nicely but the speeds are not very good. They NV+ devices are setup to...
- Jun 15, 2017
snorkleboy13 wrote:
I am referring to Default Gateway setting on the NV+. Currently it is set for 192.168.1.1When you switch to DHCP, the router also provides the gateway and subnet mask. So just change to DHCP.
Jun 15, 2017Guru - Experienced User
Start by resetting all your network clients (including the NV+) to use DHCP, and then connect them directly to the Comcast gateway (or to an ethernet switch that connects to the gateway).
After that look for an IP address reservation feature in the gateway (sometimes called ARP reservation), and reserve addresses in the router instead of assigning static addresses in each device.
You'll need to replace the aging wrt54Gs with new wifi access points if you want good speeds.
- snorkleboy13Jun 15, 2017Aspirant
I'll give this a try. I don't really use the old wireless routers for anything but legacy gear that hasn't been switched over to the faster Comcast modem/wireless router.
So:
1) Via Netgear Admin - Switch to DHCP
2) Also switch the Gateway to 10.0.01?
3) Do I need to change the DNS address to correspond to Comast?- StephenBJun 15, 2017Guru - Experienced User
Isn't it 10.0.0.1 already?
DHCP normally gives out the DNS address. Some routers will hand out 10.0.0.1 (and act as a DNS proxy). Others will pass through the original DNS services.
On the NAS, you can remove the DNS servers when you switch over to DHCP. It's safe to add 8.8.8.8 as a DNS server after you've done that. 8.8.8.8 is Google's public DNS.
RE:10.0.0.1 Yes that is what the Comcast is set for. I am referring to Default Gateway setting on the NV+. Currently it is set for 192.168.1.1
EDIT: 90% of all devices are connected via Wi-Fi using the Comcast's 10.XX.XX.XX addresses. I can work on having the router provide specific IP4 addresses once I get the NV+ sorted.
Oh, and thank you for your assistance to date.
