snorkleboy13's avatar
snorkleboy13
I have a ReadyNAS NV+ running 4.1.14 and want to switch networks
For years I had my ReadyNAS NV+ running 4.1.14 on my home network using wrt54GS wireless routers with Tomato installed. They run nicely but the speeds are not very good. They NV+ devices are setup to...
  • StephenB's avatar
    Jun 15, 2017
    snorkleboy13 wrote:
    I am referring to Default Gateway setting on the NV+. Currently it is set for 192.168.1.1
    When you switch to DHCP, the router also provides the gateway and subnet mask.  So just change to DHCP.
ProSupport for Business
