snorkleboy13
Jun 15, 2017Aspirant
I have a ReadyNAS NV+ running 4.1.14 and want to switch networks
For years I had my ReadyNAS NV+ running 4.1.14 on my home network using wrt54GS wireless routers with Tomato installed. They run nicely but the speeds are not very good. They NV+ devices are setup to...
- Jun 15, 2017
snorkleboy13 wrote:
I am referring to Default Gateway setting on the NV+. Currently it is set for 192.168.1.1When you switch to DHCP, the router also provides the gateway and subnet mask. So just change to DHCP.
snorkleboy13
RE:10.0.0.1 Yes that is what the Comcast is set for. I am referring to Default Gateway setting on the NV+. Currently it is set for 192.168.1.1
EDIT: 90% of all devices are connected via Wi-Fi using the Comcast's 10.XX.XX.XX addresses. I can work on having the router provide specific IP4 addresses once I get the NV+ sorted.
Oh, and thank you for your assistance to date.
Jun 15, 2017Guru - Experienced User
