naspro6
Dec 12, 2011Aspirant
I really did not deserve this.
Started my nas journey with an Ultra6. Great Box and never had 1 issue since purchasing it. Its still going strong. Thought I'd upgrade to a Pro6 but the experience has nearly killed me. First box...
mdgm-ntgr
Dec 12, 2011NETGEAR Employee Retired
I would still try disabling every service you can temporarily, rebooting the NAS then attempting to change hostname. If that works, then re-enable the services.
Perhaps one of the community add-ons is causing the problem.
I would think trying another support case could be the way to go here. Though as you're running a beta they may not be able help.
