BaJohn
Apr 04, 2015Virtuoso
Idle disk drive losing will to live?
I have recently seen posts about disk drives failing at first use. This kind of worries me as I bought 7 identical drives, 6 to go in my RN516 and 1 spare. Assuming I have good luck and my first fai...
Apr 04, 2015Guru - Experienced User
This post has reports from several folks who have taken disks off the shelf with no issues after several years: http://www.tomshardware.com/forum/28546 ... ong-period
The main risk I see is that if the spare does fail "early" it will likely be out of warranty.
FWIW, I keep a spare handy myself. I ran full diags on any spare (including the destructive write test) before I boxed it. I guess I could run an extended diag on it in a PC once every 3-6 months or so, but I don't.
