emobadger
May 05, 2012Tutor
Incorrect product description
I've very recently just purchased a ReadyNAS duo v2 and would like to express my disappointment in the product. After wanting to purchase a ReadyNAS for a couple of years now I was excited to finall...
mdgm-ntgr
May 05, 2012NETGEAR Employee Retired
There is a community add-on for BitTorrent: http://readynasxtras.com/readynas-arm-add-ons/transmission-arm
As for FTP this is added in 5.3.5 (currently in public beta: http://www.readynas.com/forum/viewtopic.php?f=148&t=62728). For now on 5.3.4 the RemoteiPhone add-on (see http://www.readynas.com/RAIDiator_arm_5_3_4_Notes) is needed to enable FTP for access via ReadyNAS Remote.
You can important pictures into ReadyNAS Photos II using Eye-Fi. See http://www.readynas.com/photos2
To use this features login to ReadyNAS Photos II then
yoh-dah wrote: go to the Settings (at top left), Preferences, Remote Upload, then check "Enable Remote Upload". You'll see the Eye-Fi FTP setup info that you enter in the Eye-Fi Center for FTP.
