emobadger
May 05, 2012Tutor
Incorrect product description
I've very recently just purchased a ReadyNAS duo v2 and would like to express my disappointment in the product. After wanting to purchase a ReadyNAS for a couple of years now I was excited to finall...
emobadger
May 06, 2012Tutor
Hi thanks for your reply. (and for clearing up the Eye-fi feature)
I did try installing the addon to enable FTP for the Iphone App, I posted about it here:
viewtopic.php?f=75&t=62985
Do you need to set up shares to specificly accept access over FTP/the iphone app?
The guide here seems to suggest that you do: http://www.readynas.com/?page_id=4401 mentions
"When you connect, you will see the folders you have enabled for FTP access."
But there seems to be no where you can enable such a setting.
