emobadger
May 05, 2012Tutor
Incorrect product description
I've very recently just purchased a ReadyNAS duo v2 and would like to express my disappointment in the product. After wanting to purchase a ReadyNAS for a couple of years now I was excited to finall...
DansDad
Jul 02, 2012Aspirant
jleinbach wrote: I bought a ReadyNAS Duo v2 in part because the specs indicated that it can be used as a print server..... This is a problem for me.
Are there any plans to add that functionality?
I find myself in the same position; having spent days transferring data to the ReadyNAS Duo I then sought advice on configuring the printer server from links in firmware 5.3.5 to find confirmation in
[http://www.readynas.com/?page_id=5029] "Can I attach two or more USB Printers to the ReadyNAS?" to which the answer is "Yes, you can attach multiple USB printers to the ReadyNAS."
It wasn't until I found
JabbaTheHutt wrote: Sorry for all the confusion regarding the print server on Duo/NV+ v2. The print server feature will not be enabled on these products.
that I realised I had wasted both time and money on this device.
If that is the formal response from Netgear, then this is the first and last device I shall ever buy from that manufacturer.
I expect a response to this posting that is less dismissive about what amounts to blatant mis-selling.
Just one more example of American corporate behaviour having an adverse effect on the British!
