Pornlapas
Nov 09, 2015Aspirant
Install a second Hard Disk into the NetGear ReadyNAS cabinet
I need some help.... I have connected my ReadyNAS to my router and already installed a 500 Gb Tishiba disc inside,...its working fine. Now I want to add a 2 Tb WD disc, but the system can't seam to f...
BrianL2
Nov 09, 2015NETGEAR Employee Retired
Hi Pornlapas,
To know the status of the newly added disk, either you open the device admin page (frontview) or the RAIDar utility in your PC. If the disk LED is blinking, probably it's doing a resync.
Let me know if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team
- PornlapasNov 10, 2015Aspirant
Thank you for the answear,........
The light in the front has stoped blinking and in the admin...online, I can see both disks in green status,....looks ok....
BUT, I still cant use it, its just the other disk that shows on my macbook desktop.......
There is another disk showing, but then I have to usa a password,....and I have no clue about witch one.....
- StephenBNov 10, 2015Guru - Experienced User
What NAS do you have and what firmware is it running?- PornlapasNov 10, 2015Aspirant
.....its a RN102. Firmware: 6.4.0
In slot one there is a Toshiba 500 Gb,.....running nicely....
In slot two, there is a WD; WDC WD 20EFRX-68EUZND - Firm ware; 82.00A82 - SATA - Volumename: New
In the Admin Page Its set to;
X-RAID, both disk as showing in the picture with the green dot under for each disk, but to the left,
inside the light blue aera "Data".....there is only the Toshiba disk showing.....
In the "Performance" area both of the disks are showing with green light, temperature ++++
what the f.... is this....
