venturadeb
Apr 21, 2012Aspirant
Install Observations
I have an NV+ v2 with 3 terrabyte hard drives (four). I purchased the V1 originally and discovered it will not handle 3 terrabyte drives (bought the wrong one). I am still trying to get the system...
mdgm-ntgr
Apr 21, 2012NETGEAR Employee Retired
1) You can do a factory reset via the Dashboard (web-interface) or via the boot menu. Of course the NAS needs to be working for the web-interface to be up and running. As there is no login when accessing RAIDar itself, doing a factory default directly via that could be a security risk.
2) Sometimes used disks need the partitions deleted off them. After that a factory default should work.
4) Correct. It cannot join a domain. The NV+ v2 is targeted at the home user or the small business user who doesn't have a domain.
6) Can you open RAIDar? If you hover the mouse over the volume LED you should see an indication of the progress.
