venturadeb
Apr 21, 2012Aspirant
Install Observations
I have an NV+ v2 with 3 terrabyte hard drives (four). I purchased the V1 originally and discovered it will not handle 3 terrabyte drives (bought the wrong one). I am still trying to get the system...
Apr 22, 2012Guru - Experienced User
This is not really comparable. First of all, building the raid array takes longer with the bigger partitions.
venturadeb@yahoo.com wrote: I have an NV+ v2 with 3 terrabyte hard drives (four). I purchased the V1 originally and discovered it will not handle 3 terrabyte drives (bought the wrong one).
I am still trying to get the system up and running after a few days. If I had left it in the v1 with 750gb partitions, I was up in a few hours...
And it looks like your setup issues with the V2 happened because you initially installed your disks in the V1. If you had started cleanly with the V2, your experience would likely have been different.
