GNijhuis
Sep 15, 2015Aspirant
Installation Problem NAS102
Hello,
This afternoon i bought a new NAS102 with two WD Red Nas Hard Drives.
I tried to setup the NAS but it won't work.
The problem is that the NAS can't be found using the Readycloud (https://readycloud.netgear.com).
When I use Raidar then I see the NAS with one IP adres, but also there stands that there are no harddrives locates.
So I cant do anything with the Raidar.
I already tried to reboot the NAS (after I start the NAS again the blue light (of the power) blinks very fast, after that he keeps on and again after that he blinks again en keeps doing that). I also tried to find him without an active firewall or virusscanner. I also tried an another computer on my network.
I also tried to connect with the IP adres but nothing works.
I'm now out of options, I really hope that someone can help me because I'm getting a little bit desperate.
- mdgm-ntgrNETGEAR Employee Retired
Have you checked to make sure that the disks are properly seated?
