Shardstrat's avatar
Shardstrat
I/O errors, unspecified disk
Two questions:
1) I've been getting error messages that say "Access to the disk on channel (??) is producing I/O errors. Although the array is still redundant, please replace this drive as soon as possible, as it is likely to fail soon."
How can I find out which of my four drives "this drive" is so I can replace it? I've been waiting for two days for an answer from the local Netgear tech support.
2) Also, Netgear tech support told me that to go into Tech Support/Debug mode, I need to power up the ReadyNAS with the hidden reset button depressed and hold it down until "Tech Support" appears on the LCD display. I tried this and never got "Tech Support" on the display - what I got was "TFTP ARP Error - Retry - kernel_init". I later found out that to get into Tech Support mode I need to press and hold the power button, not the reset button. Have I deleted all my data?
TIA
Les
NV+
3x Samsung SpinPoint 1 T
1x Seagate Barracuda 1 T
1 Reply
  • Update: Tech Support responded and said that Disks 3 and 4 had bad sectors. They told me to clone at least one of the disks and then boot up up using three disks. I cloned Disk 3 and replaced it with the cloned drive, and when I booted up I received a message saying "C:\ 0/0 GB available", then "Volume C:\ is dead", then "C:\ 1/1 GB available". Frontview shows disks 2 and 3 as containing data, but Disk 1 as containing no data. I'm currently waiting for Tech Support to call back.
    ____________________________
    Update: Tech Support told me to boot into Debug mode and wait for instructions. Two days later, Level 3 Tech Support sent me an e-mail telling me to do what I've already done - clone a disk, replace the defective drive with the cloned one, and try to boot. They also told me to open Port 23 on the NAS. However, since I've been in Debug Mode all this time, they already have access to the NAS via telnet. A call to Level 2 support confirmed this. Now I am waiting for another response from Level 3 support, who seem unaware of the history of the case or of the fact that the NAS is available to them via telnet and has been for the past three days.
    Meanwhile I have cloned Disk 4, which was obviously the most defective one. In fact Disk 3 showed a total of only four errors during the cloning process (I can post the output). I was able to clone Disk 4 up to 66% using dd_rescue before reaching a point at which no more data was being copied, and then in the reverse direction up to the 36% level. So theoretically most of the data have been cloned.
    My questions are:
    - Could booting the NAS while holding in the reset button, as I was told to do, have been responsible for making the data on Drive 1 inaccessible?
    - If not, why is Disk 1 showing no data?
    - Can the data be recovered from Disk 2 and the clones of Disks 3 and 4?
ProSupport for Business
