DLSchmidt11
May 26, 2017Tutor
Genie Timeline Unspecified Error
Getting an "Unspecified error" from Genie Timeline resident App that keeps repeating every second with annoying sound. Acknowledging the error pop-up window does not clear message because it keeps repeating. I believe the error was initiated when I interrupted (paused) a ReadySHARE backup that was unintentionally started. Subsequently, I restarted and completed the backup, but the repeating error message continued throughout and thereafter. The only way I was able to stop the message and beeping was to use Task Manager to terminate the process GenieTimelineService.exe. Obviously this drastic action defeats the scheduled backups by the ReadySHARE application. How can I permanently clear the error message? Also please fix the bug that initially triggered the error and please eliminate the unnecessary annoying beeping from the logic.
- DexterJBNETGEAR Moderator
Hi DLSchmidt11,
Have you tried uninstalling and re-installing the app then going through the backup setup again?
Dexter
Community Team
Thanks for the feedback Dexter. I did as you suggested and unintstalled, then re-installed the ReadyShare Vault application on my Windows XP desktop Dell computer. This cleared the error. I then modified the backup settings (frequency and max storage size) and started a new backup. This new backup ran to 99% complete (1 item remaining) and again triggered the repetitious "unspecified error" message. Again the error will not clear when acknowledged. I subsequently rebooted the PC and the error message returns. I re-opened the ReadyShare app, which still showed 99% complete, then paused and resumed the backup. The backup status now indicates 100% complete, but the error meesage persists.
I have also since installed ReadyShare Vault on my new Windows 10 Dell laptop and sucessfully ran a backup with no error messages. Do you have any other ideas regarding the "unspecified error" message that continues on my Windows XP machine?
Darrell
- AbueloAspirant
- bfd245Aspirant
i also have the same issue on my Nighthawk X6 R8000 .
- dprice03Aspirant
Hello I am also getting this annoying error message (Genie Timelline Unspecified Error). From reading through the posts, simply uninstalling it does not work. PLEASE let me know how to PERMANENTLY remove this annoying error message. Thank you!
- Install the old version. The new one won't work
- evandeneAspirantI have the same problem. Genie Timeline error (Windows 10) From where can I download the old version? I found a link somewhere but that didn't work anymore
- Install the old version. New one won't work
Hi ,
I am experincing teh same issues.
Where do I download the old version from?
My R6700v2 disconnects from the internet every day and it seems this generates the error message in the GenietimeLine error... or coud it be the other way around?
Anyway, can you please advise to remove this annoying error? I have to switch of my speakers - which has other consequences!
thanks in anticipation,
Allan
- LeesmithAspirantI’m getting the error to can I just delete the program off my computer. It’s very annoying
- Yes
