Teufl_at_Readyn
Feb 15, 2014Tutor
IPV6 (DDNS) Update Script for afraid.org
Hello Everybody, since I had problems updating my Readynas IPv6 IP, I would like to post my solution for DDNS via afraid.org. Beforehand, there is an app for dynamic dns updating you could try firs...
Teufl_at_Readyn
Dec 06, 2014Tutor
It seemes the output of "ip addr show" or ifconfig has changed so the first output is the local IPv6 Adress. Quick talk to my friend brought the following conclusion, which I will (have added) in the above script, also.
If you have the script already in use, replace
with
ip6_cur=`/sbin/ip addr show eth0 | grep -m 1 "inet6" | awk '{print $2}' | awk -F'/' '{print $1}'`
with
ip6_cur=`/sbin/ifconfig eth0 | grep "inet6 addr" | grep -Evi -m 1 "inet6\s+(addr:\s+)?(fe80|fd)" | awk '{print $3}' | awk -F'/' '{print $1}'`
