ionizer5's avatar
ionizer5
Is it possible to easily remove the door hinge on an RN104 to replace a missing one on a RN314 ?
I had an RN104, but the chassis died (confirmed with support).
I had to go on the aftermarket for a replacement and got the RN314.
However, the RN314 I got is missing the door hinge.  I want to take the door hinge off the RN104 and replace it onto the RN314
However, I don't see any easy way to do this without opening up the entire unit or risk breaking the tabs that hold the door in.
Is there any trick or does it require me to disassemble the unit?  I was hoping to avoid that because I don't want to accidentally create a problem with the new unit in the process
  • ionizer5
    I don't think there's any other way to remove and reinsert the door part without disassembling the whole unit.
    If you are not comfortable might be better to have it done by a technician.
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    ionizer5
      • Sandshark's avatar
        Sandshark
        Sensei
        When I buy a used NAS, the very first thing I do is open it up and blow out all the dust.  I don't have a 104/314 to see how hard it is to remove the front panel and door assembly, but it's not too hard on most.  On one's I've disassembled, the only thing wired is the display, and it's plug-in.  The buttons and LEDs are just extensions to ones mounted on the circuit board underneath.  It's a much bigger deal on a 6-bay unit because of the lighting and sensor panel in the door.
        If the 104 and 314 are to each other like all the legacy 4-bay units are to their siblings (and it looks like they are), it can even be easier to just swap the motherboard, daughterboard (if any), and back panel.
ProSupport for Business
