Toroidal2's avatar
Toroidal2
Is Netgear Readynas 202 still compatible with PLEX ?
Hello Folks,   Does Netgear still support PLEX server ?   Since the las OS update 6.6.0 Plex no longer works. I only bought the Netgear because it was compatible. If this is no longer the case, t...
  • StephenB's avatar
    Oct 09, 2016
    Toroidal2 wrote:
    Thanks for the answer.
    Just to prevent any confusion - I don't work for Netgear.  I believe Plex supports all their platforms directly ( from all NAS vendors).
    But your response seems a bit extreme, since Plex says that their plexpass release already fixes it.  Likely this will be released mainstream soon.
    Personally I run plex on a pc, mapping the NAS shares to a drive letter.
ProSupport for Business
