JoeM845
Oct 18, 2016Luminary
Is RAIDiator update 4.1.15 compatible with RND4000? Web link broken
I received an email saying RAIDiator 4.1.15 was available. I took the email link to http://kb.netgear.com/app/answers/detail/a_id/30914. There I wanted the double-check that the update applied becaus...
- Oct 18, 2016
JoeM845 wrote:
Can someone verify is this update applies to the RND4000 (v1)?
It does apply to the v1 (which runs 4.1.x firmware).
The kb article link is correct.
A direct link to the zip file is http://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator-4.1.15.zip
Extract the image from the zip, and manually install it through the frontview web ui.
Oct 18, 2016Guru - Experienced User
- JoeM845Oct 18, 2016Luminary
Thanks. I was not aware that all the 4.1.x firmware versions applied to the RND4000 V1.
Are you saying that the "Applies to" links on the KB article page work for you? I got the failure in MSIE 11 and Firefox.
Joe
StephenB wrote:
JoeM845 wrote:Can someone verify is this update applies to the RND4000 (v1)?
- StephenBOct 18, 2016Guru - Experienced User
It works for me in Chrome, Firefox, and IE 11
- DaneAOct 20, 2016NETGEAR Employee Retired
Hi JoeM845,
The "Applies to" links that you are referring to on the KB article mentioned works for me. I am using Google Chrome.
DaneA
NETGEAR Community Team
