Retired_Member
Jun 06, 2016Is Seagate 8TB NAS HDD SATA 6Gb/s NCQ 256 MB Cache Bare Drive ST8000VN0002 compatible?
ReadyNAS 316, OS 6.5.0
I have seen the post talking about the Western Digital new 8TB Red HDD but I just noticed Amazon has the Seagate 8TB NAS HDD SATA 6Gb/s NCQ 256 MB Cache Bare Drive ST8000...
Jun 07, 2016Guru - Experienced User
The ST6000VN0001 is on the HCL, so I think there's good reason to think the 8 TB model will work as well.
The larger drives sometimes have non-standard mounting, so you might google for that. The WD 8 TB shifted the screw hole positions on the bottom, but not on the side - so there was no issue. My guess is that Seagate did that too, but its probably worth checking.
Netgear might deny support of course. But I suspect they will add the 8 TB models shortly.
BrianL2
Jun 07, 2016NETGEAR Employee Retired
Hi DJDOC,
Our ReadyNAS units will accept any standard SATA HDD but using the ones that are not listed in our HCL comes with a risk. Anyway, a positive feedback is found on this thread and you should be able to install this HDD on your system.
Kind regards,
BrianL
NETGEAR Community Team
- Retired_MemberAug 18, 2016
Campus has me a bit scared but I'm going through with it. I'm almost out of space!
- mdgm-ntgrAug 18, 2016NETGEAR Employee Retired
There are other 8TB disks out there e.g. from WD.
