BotanyBay's avatar
Sep 17, 2017
Is the EDA500 discontinued?
Looking online to purchase an EDA500 expansion chassis and it appears that it is a "discontinued item".  Is this model being replaced by something different?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Getting an additional ReadyNAS and hooking that up to your network provides much better performance and better value imo than getting an EDA500.
    • BotanyBay's avatar
      BotanyBay
      Tutor
      I understand that, I am looking to use the unit for a specific purpose of moving data between two locations and thought that the unit might be ideal.
      I am just looking for confirmation if it is no longer being manufactured?
      • Sandshark's avatar
        Sandshark
        Sensei
        It's not designed with that in mind.  You would be better off with a USB3 based device.  If you need more space than a single drive can handle, I have successfully used another manfacturers USB RAID device with a ReadyNAS.
        Amazon had a fire sale on the EDA500 a few months ago, which did make me suspect that it was being discontinued.
        If you really want one, there are a couple for sale on eBay.
ProSupport for Business
