bokenrosie
Jun 25, 2012Tutor
Is the grass greener with ReadyNAS Ultra 2
I'm looking at the hardware compatibility list and the WD 3TB drive is no longer available. Are there other WD 3TB drives I can use? I like the idea of running a full version of Squeezebox on a NAS ...
bokenrosie
Jun 26, 2012Tutor
The drive I'm looking at is the WD30EZRX. The RS version of this same drive is what is listed in the HCL however that disk is not available at either Newegg or Amazon which leads one to believe it's been replaced - possibly with this other one. The 4 drive Ultra brings my start up cost up an additional $180. Are you saying that if I start out there with 2 x 3TB setup that I can add another 3TB in the form of only one drive at the point that I run out of space? That's an interesting proposition if it is the case.
