jeburnett
Apr 29, 2012Aspirant
Is the WD30EZRX not on the HCL because....
A. It has not been tested yet? or B. It has been tested AND unresolved issues were found? The HCL list is sacrosanct however, the listed WD30EZRS has become essentially unavailable AND some...
beisser1
Jun 22, 2012Tutor
PapaBear wrote: Rudy-san - the sparc based ReadyNAS units will not support drives over 3TB. It is an issue with the kernel used in the OS and is not fixable. Until the 3TB drives came on the market, this was not known to the development staff. This is the main reason it was discontinued and the v2 series with a new chip and completely new OS was developed. Stick with the Hardware Compatibility List (HCL) and you will be OK.
you mean it wont support drives over 2 tb, not 3 :)
