JBDragon1
Sep 29, 2020Virtuoso
Issues on my ReadyNAS 516, System Volume root useage 93%
So I've been getting this Error Message System Volume root usage 93%. So I'm pretty sure it's PLEX. I need to figure out how to move it's Database over to the Media side. I think it's the Video...
Sep 30, 2020Guru - Experienced User
So I'm pretty sure it's PLEX. I need to figure out how to move it's Database over to the Media side. I think it's the Video Preview thumbnails really eating space up.
Apps are supposed to put their data in /data/.apps, which is mounted as /apps on the root. Some don't do that as they should - but plex does. I have it installed on my RN202, and am only using 16% of the OS partition on that machine.
Thumbnails are stored in /apps also - in the case of the RN202, they are in /apps/plexmediaserver-annapurna/MediaLibrary/Plex Media Server/Media/localhost
So I think your guess on the cause is incorrect.
I have seen plex sometimes fill up the OS partition with temporary transcoded files, but that doesn't appear to be a big factor here.
As far as where the space is going, the big offender is
1.4G /mnt/opt
This folder has about 4.6M on my RN526.
This folder (although still fairly small), has more in it than normal:
185M /mnt/root
Mine shows 36k. Normally this folder just contains some hidden files/folders (.bash_history, .bashrc, .profile, and .ssh)
These two are also larger than what I have:
940M /mnt/usr
817M /mnt/var
My usr folder is only 243M, and /var is 612M.
- JBDragon1Sep 30, 2020Virtuoso
I'm using the program WinSCP to look at the NAS. It's showing my Apps in /apps/
The MediaLibrary is in /apps/plexmediaserver/
At the time when I had the Video Preview Files turned on in PLEX, it was eating up 130+ Gig's all by it's self. I keep getting the e-mail "System volume root's usage is 93%. This condition should not occur under normal conditions. Contact technical support."
I have over 1200 Movies and 5000 TV episodes. So it's a big database and having The Preview thumbnails ,which is nice, taking a huge chunk of space. Turning it off reduced the space used, but for some reason I'm still at 93%. I have 20TB of Data with 10TB of free space.
I just looked and the Plex MediaLibray is down to 46.8GB. That's like 1/3 of the size it was.
I don't know what I'm missing here.
It'll take days to backup. Wipe the NAS, Days to copy everything back. Days more to get the software I use installed and working again like it should since some I have to manually SSH install and setup. Remember how I had to do everyone once again, Ouch.
If it's not PLEX, then what in the world could it be eating up all the space?
- schumakuSep 30, 2020Guru - Experienced User
JBDragon1 wrote:I'm using the program WinSCP to look at the NAS.
Not the best way to investigate ... use the Linux shell.
JBDragon1 wrote:It's showing my Apps in /apps/
As StephenB already mentioned - /apps/ does not reside on that root partition the warning email is about...
root@RN628X:/mnt# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/md0 4190208 740096 3053888 20% / <<<<< this is what your warning e-mail is causing!!!!
.../dev/md127 323185536 208920 319821608 1% /apps <<< this is where your Plex media library et all does reside. That's all fine.
(Don't worry about my device low capacity on my /dev/md127 - this is an all SSD system serving a specific applicaion.)
JBDragon1 wrote:At the time when I had the Video Preview Files turned on in PLEX, it was eating up 130+ Gig's all by it's self. I keep getting the e-mail "System volume root's usage is 93%. This condition should not occur under normal conditions. Contact technical support."
Stephen already pointed to the sections residing on the root partition - these are the folders to investigate!
If your Plex library is 50 or 150 GB can't be relevant as this is outside of the root volume. Again, WinSCP does show a complete tree, easy to overview mounts and symlinks going past a volume...
- StephenBOct 01, 2020Guru - Experienced User
And you should already have seen that, since /mnt/apps is completely empty in your earlier post. The NAS root has several mount points where portions of the data volume are mounted. The whole point of re-mounting the root as /mnt is to let you analyze the root itself (without those mount points getting in the way).
Look in the folders I pointed you to earlier.
