gso
Apr 14, 2020Guide
iTunes sync
Currently I have my iTunes music files on the NAS. I manually copied them to the music folder in ReadyCLOUD. My main source for these files is in my iTunes/music folder on my Mac. The music is outdat...
Marc_V
Apr 15, 2020NETGEAR Employee Retired
Here's a guide onusing the ReadyCloud Client sync feature
Please note though that this will create a new Share folder on the NAS. So transferring it to the original NAS Share for your music will need to be done manually.
Another option is to manually transfer it to the folder but I also agree it would be good to automatically sync any changes on your source.
HTH
Regards
gso
Apr 15, 2020Guide
The link you showed looks pretty straight forward. But I don't understand your caution about having to the transfer manually. Doesn't it say that once I request the backup it will create the folder on the NAS and transfer the data (music in my case) to the NAS? Before I do this I will probably delete my existing NAS Music folder.
