gso
Apr 14, 2020Guide
iTunes sync
Currently I have my iTunes music files on the NAS. I manually copied them to the music folder in ReadyCLOUD. My main source for these files is in my iTunes/music folder on my Mac. The music is outdat...
Apr 15, 2020Guru - Experienced User
gso wrote:
Currently I have my iTunes music files on the NAS. I manually copied them to the music folder in ReadyCLOUD. My main source for these files is in my iTunes/music folder on my Mac. The music is outdated on the NAS ...
If the Mac is at home, there are other options than ReadyCLOUD (which has a lot of limitations on syncing).
For instance, FreeFileSync could be installed on the Mac, and could update the music folder on the NAS on a schedule. It could also back up other files.
I'd go with something like that myself (unless there's a specific reason you need to use ReadyCloud).
gso
Apr 15, 2020Guide
Thanks for the options. I guess I could probably use Carbon Copy Cloner to do this as well but I get a warning I don't understand (attached) so I didn't go ahead with it.
- StephenBApr 15, 2020Guru - Experienced User
You aren't using any credentials when you are accessing the NAS folder - that will work if you allow anonymous access to the share.
Though it would be better to create a user account on the NAS, and use it's username password.
- gsoApr 15, 2020Guide
Thanks. I always have to sign in to my Readycloud account. How would I use a user/pw just for the folder?
I'm not sure why you're using ReadyCloud at all, so that might be worth clarifying. Is it for remote access (when away from home)?
If you are connected with the ReadyCloud app, you could use your existing ReadyCloud user/password. If you aren't always using ReadyCloud then you'd create a new account on the NAS accounts page.
As far as using that credential - if you are using finder, you'd choose the option to connect as a registered user, and then enter your user/password. I'm not a mac owner, so I can't give you much more help than that.
