techyguy38
Feb 27, 2019Follower
Java install RN214 OS 6.9.5
I am attempting to install Java to use the Unifi Controller. Whenever I try I get a bunch of dependancy errors. See below
root@REDQUEEN:/# apt-get install -t jessie-backports openjdk-8-jdk
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
gcc-4.9-base : Breaks: gcc-4.9-base:armhf (!= 4.9.2-10+deb8u2) but 4.9.2-10+deb8u1 is to be installed
gcc-4.9-base:armhf : Breaks: gcc-4.9-base (!= 4.9.2-10+deb8u1) but 4.9.2-10+deb8u2 is to be installed
libgcc1 : Breaks: libgcc1:armhf (!= 1:4.9.2-10+deb8u2) but 1:4.9.2-10+deb8u1 is to be installed
libgcc1:armhf : Breaks: libgcc1 (!= 1:4.9.2-10+deb8u1) but 1:4.9.2-10+deb8u2 is to be installed
libstdc++6 : Breaks: libstdc++6:armhf (!= 4.9.2-10+deb8u2) but 4.9.2-10+deb8u1 is to be installed
libstdc++6:armhf : Breaks: libstdc++6 (!= 4.9.2-10+deb8u1) but 4.9.2-10+deb8u2 is to be installed
openjdk-8-jdk : Depends: openjdk-8-jre (= 8u171-b11-1~bpo8+1)
Depends: openjdk-8-jdk-headless (= 8u171-b11-1~bpo8+1)
Depends: libx11-6 but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
root@REDQUEEN:/#
I have tried everything I can find online.
