rgollar
Mar 01, 2015Aspirant
Just loaded readynas 516 with these drives (ST8000AS0002)
I just wanted to let people know that the readynas 516 is working just fine so far with Seagate ST8000AS0002 8TB hard drives. I so far have populated it with 4 of them and it has had no problems. Once...
rgollar
As far as fitting in the bays I had to shave off one of the plastic nubs in the middle of the quick change tray because the hard drives did not have all the holes down the side of it other then that they fit great. So far it says the X-Raid is working good.
