rgollar
Mar 01, 2015Aspirant
Just loaded readynas 516 with these drives (ST8000AS0002)
I just wanted to let people know that the readynas 516 is working just fine so far with Seagate ST8000AS0002 8TB hard drives. I so far have populated it with 4 of them and it has had no problems. Once...
Mar 02, 2015Guru - Experienced User
Yes.
mdgm wrote: Hopefully over time there will be newer disk models in these capacities with conventional physical layouts (in terms of where the holes are etc.).
FWIW, modifying the disk tray carries some risk (the plastic nubs are there for a reason...), so its not something I'd recommend..
