rgollar
Mar 01, 2015Aspirant
Just loaded readynas 516 with these drives (ST8000AS0002)
I just wanted to let people know that the readynas 516 is working just fine so far with Seagate ST8000AS0002 8TB hard drives. I so far have populated it with 4 of them and it has had no problems. Once...
AndreasKa
Mar 02, 2015Tutor
Interestingly, when you look at the spec sheet, it's rated for 24x7 operation.
The difference between this drive and the Enterprise Capacity drive is much lower workload rate limit, lower MTBF and lower Non-recoverable Read Errors per Bits Read rating
