rgollar's avatar
rgollar
Just loaded readynas 516 with these drives (ST8000AS0002)
I just wanted to let people know that the readynas 516 is working just fine so far with Seagate ST8000AS0002 8TB hard drives. I so far have populated it with 4 of them and it has had no problems. Once all 6 are done I will post back to let any one that wants to know these 8tb drives work. So far with 4 populated with 8tb drives and the other 2 are 4 tb drives its working just fine.
  • Hey @rgollar. Do you have any performance stats for running these 8TBs in your server? I'm about to put 6 of these in my ReadyNAS 6 and was just hoping it could saturate the gigabit link. With just 2 disks I see speeds vary from 30-160MB/s when writing. Reads have been consistent.
  • I have had no problems yet as far as speeds. If I copy a file say 2 gb its stays steady at around 108-118MB/s but when I copy a file say 8gb it usually goes down to around 96MB/s but its stays steady there. What I have found is if I have used my computer alot to download stuff that I need to reboot the computer to maintain speeds. Other then that I have been running smoothly.
  • Hey @rgollar. Just had one last question for you. Do you know how long/how fast your initial sync was on these drives? I just installed 6x8tb in my ReadyNAS Pro and the sync is showing something like 6 days to complete, hovering around 16MB/s sync:
    root@pro:~# cat /proc/mdstat
    Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
    md127 : active raid6 sdf3[5] sde3[4] sdd3[3] sdc3[2] sdb3[1] sda3[0]
    31236707328 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/6] [UUUUUU]
    [=>...................] resync = 6.4% (502031968/7809176832) finish=9243.5min speed=13174K/sec
    md1 : active raid6 sdf2[5] sde2[4] sdd2[3] sdc2[2] sdb2[1] sda2[0]
    2094848 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/6] [UUUUUU]
    md0 : active raid1 sdf1[5] sde1[4] sdd1[3] sdc1[2] sdb1[1] sda1[0]
    4190208 blocks super 1.2 [6/6] [UUUUUU]
    unused devices: <none>
    I'm ok if this is the one time cost, but even at 15MB/s, this seems low for these drives.
  • I only upgraded one drive at a time. I previously had it with 4tb drives in each bay. So when I updated it I swapped one out at a time and let it up date. It took about 1 1/2 to 2 days each drive. I also waited 3 days between adding each hard drive, just to make sure there wasnt any problem before I added another drive.
    Thanks for the info! I'm assuming you're also with X-Raid2 dual redundancy? This will be about a week for all the drives to sync.. which seems in line with your 1.5-2 days per drive.
ProSupport for Business
